It is currently Wed Apr 30, 2025 5:42 pm
 Post subject: Shes real fine!
PostPosted: Thu May 08, 2014 2:46 pm
Got a line on a 63 409 that i believe is not real but its said to be all there!
Needs a rebuild motor, possibly bodywork etc but not terrible car!
What should i do?
S/A??
Nostalgia??
Run away?
The only replacement block/heads are aluminum!
But a 4 speed dual quad positraction 409 is on my "cool" list
 Post subject: Re: Shes real fine!
PostPosted: Thu May 08, 2014 2:51 pm
Is it an Impala or the holy Grail of 409s a Bubbletop? What's wrong with a Nostalgia Super Stock??? :drive
You got to do it just to make me happy. Maybe you'll need a driver for handicap racing with lots of 4 speed experience. :rock
PostPosted: Thu May 08, 2014 6:12 pm
Stock appearing would be a challenge, but what a challenge! That's a mans car it is.
PostPosted: Thu May 08, 2014 6:46 pm
Awesome to say the least Very cool if that is the case. Just sayin
PostPosted: Thu May 08, 2014 6:47 pm
I think that I have 30 plus wheel time on a stick impala I should be one to take one for the team. :rock
PostPosted: Thu May 08, 2014 6:50 pm
Hal, i think i did ok w my 4 speed but i would let you drive it anytime too!
I think there was a lower hp 4bbl auto correct but if i do it it will be a stick
If only i could get the replacement hardware approved! :pop
PostPosted: Thu May 08, 2014 6:55 pm
I will def be planning this out before i buy it!
Hal, what do you think it could run w stick and skinnys w a max effort 409
PostPosted: Thu May 08, 2014 7:19 pm
I know at least one of those cars in pure stock trim has gone high 12s. I say go for it, they have a killer cool factor.
PostPosted: Thu May 08, 2014 8:31 pm
Hal, what do you think it could run w stick and skinnys w a max effort 409[/quote]
Hayden Proffitt ran high 11s with 12.5-1 compression and a .511 lift cam 4:56 gears and shitty tires and track prep in 62 at 3550lbs. Prepaired A/S sticks ran mid 12s at 11-1 compression. These cars can go pretty good. Oh, did anyone mention , they are cool too. :aok
PostPosted: Fri May 09, 2014 6:45 am
Hayden Proffitt ran high 11s with 12.5-1 compression and a .511 lift cam 4:56 gears and shitty tires and track prep in 62 at 3550lbs. Prepaired A/S sticks ran mid 12s at 11-1 compression. These cars can go pretty good. Oh, did anyone mention , they are cool too. :aok[/quote]
dead on with your knowledge Hal. :rock :bow :bow :bow :bow :bow
http://haydenproffitt.com/ALL_TIME_TOP_TEN_STOCKER.html
PostPosted: Fri May 09, 2014 1:30 pm
Hal, they had 15" rims right??
I can run G70 15 tires per our rules!
PostPosted: Fri May 09, 2014 8:20 pm
Ted, 14" only, that includes the wagons too. But whats wrong with G70-14s? You do get 4 link well 3 link suspension.
PostPosted: Sat May 10, 2014 5:18 am
Nothing wrong, just saying i can go to a G70!
Thats a little help!
PostPosted: Sat May 10, 2014 5:57 am
For the rear suspension I would go with a boxed lower control arm and then add an additional upper torque arm which is what they did back in the day. From people who I have spoken to who raced these cares back in the day the additional torque arm would really reduce that axle hop these cars like mine are know for. Man I really want to see this car and then see it in action. Would love to see that launching with the left front tire in the air with the right on the ground thanks to that wonderful X-frame
PostPosted: Sat May 10, 2014 6:12 am
Believe it or not the only two different sizes where 7.00-14 and on the station wagons it was 8.00-14 a big whopping difference of 4 1/2" tread versus 4 3/4" tread on the road from the factory so the G70 are a huge advantage
Users browsing this forum: No registered users and 102 guests
