It is currently Wed Apr 30, 2025 5:36 pm
 Post subject: 2013 Points Championship Payout Prizes......
PostPosted: Wed Jan 22, 2014 10:56 am
Prize amounts are subject to change without notice
$700.00 in $100.00 & $50.00 Championship Certificates from Lenny Croteau at Ultimate Converter Concepts.
http://www.ultimateconverter.com/
 Post subject: Re: 2013 Points Championship Payout Prizes......
PostPosted: Wed Jan 22, 2014 10:57 am
$500.00 in $100.00 & $50.00 Championship Certificates from Billy Atwood from Auto Services of Old Saybrook.
Championship Certificates are valid towards services, performance tuning. (To be used toward Labor)
http://autoserviceos.com/
Two complete Sets of Event and Show Field passes to a Carlisle Event in 2014 Valued @ $100.00 for each set, from Carlisle Production
http://carlisleproductions.com/ce/event ... nationals/
PostPosted: Wed Jan 22, 2014 10:58 am
$500.00 in $100.00 Championship Certificates from PST Precision Shaft Technolagies.
Championship Certificates are valid towards Parts and Service.
http://www.pstds.com/index.htm
Lebanon Valley SuperCar Nationals Oct 19, 2014 Race Entry Fee Valued @ $50.00
Raceway Park Mopars @ E-Town August 23, 2014 Race Entry Fee Valued @ $50.00
PostPosted: Wed Jan 22, 2014 10:59 am
Cecil County Nastalia Nationlas June 14, 2014 Race Entry Fee Valued @ $50.00
Randy Juliani
"MrRandyj"
Chrysler Transmision Specialist
Up for grabs is a World Class Rear Low Reverse servo:
My rear servo piston is a 1-piece design that replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. Thats right, my 1 piece piston replaces all 5 of those pieces. Mine is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. It comes in a kit with a heavy duty stainless steel return spring that will eliminate 1-2 shift overlap, a Teflon coated seal, and a .075 extra thick retainer made from stainless steel that will not bend around the retaining ring and come out of the case like the factory steel retainers do. This kit fits 67 and newer 727, 518, 46RH, and 46RE transmissions.
PostPosted: Wed Jan 22, 2014 11:00 am
5 Championship Certificates from Compu Flo Performance Head service and Machine Shop.
Each Championship Certificate is good toward $150.00 off Short Block Purchase
OR
$75.00 off Rotating Assembly or Porting Work.
$250.00 in $50.00 FireCore50 Championship Certificates
$200.00 in $100.00 Championship Certificates from Duane Porter from Porter Racing Heads
Championship Certificates are valid towards services, (To be used toward Labor)
http://supercarraces.com/Porterracing.html
PostPosted: Wed Jan 22, 2014 11:01 am
Payout amount $400.00 in $100.00 Championship Certificates from Gene Schaefer at Central CT Coatings Inc.
PostPosted: Wed Jan 22, 2014 11:51 am
that's an impressive list.
bill
PostPosted: Thu Jan 23, 2014 6:16 pm
It's time to make some phone calls to the top 15 in the points series.
PostPosted: Sun Jan 26, 2014 10:26 am
It's great to see that kind of support from our sponsors :bow
Users browsing this forum: No registered users and 88 guests
