 Post subject: Att. ALL SuperCar and FAST Racers. racing on 11/9&10/2013
PostPosted: Mon Oct 28, 2013 9:36 am
Attention ALL SuperCar and FAST racers Running Stock Appearing 11.70 E/T or Quicker, Stock Class Running 12.70 E/T or Quicker attending the Record Runs Days, Fall Finale weekend November 9 & 10, 2013. You will be required to pass tech inspection Saturday & Sunday morning before you are allowed to qualify for the event. Before Qualifying SuperCar officials will do a complete: Trunk, Suspension, Interior, Fuel system including checking for Oxygenated Leaded Fuel, Tire, and Inspection of other key components to confirm you are in compliance with ALL SuperCar rules. At the end of the day after you have competed you will be required to remove your valve cover to check casting number and you will be required to remove your carburetor to check intake. (Bring any gasket you may need to comply with inspection) If you are only coming for Sunday you will be required to remove your valve cover and carburetor at the end of the day. If you have any question please E-mail or call Ralph Barbagallo. If your car does not pass inspection you will not be allowed to qualify or participate in the class. Your money for entry will not be refunded. Remember to bring a set of Valve Cover Gaskets and Carburetor Gaskets.
Users browsing this forum: No registered users and 98 guests
